The Pentax 5mm XO
A Planetary Weapon of
Choice
Over the years I have
heard nothing but accolades for the Pentax 5mm XO when discussing
planetary performance. Unfortunately, due to its comparatively high
price and the lack of many focal lengths, I¡¦ve never been able
to convince myself to purchase one. After the 6mm Planetary Eyepiece
review I conducted, where I compared some truly world-class glass, I
thought my quest for the holy grail of planetary eyepieces would be
over. As satisfied as I was after experiencing so many top-tier
planetary eyepieces, past praises for the untried 5mm XO still
haunted me. Finally, through the kind generosity of CN member Ed
Kessler who loaned me this eyepiece, I¡¦ve been able to put my
nagging questions firmly to rest.
Focal
Length:
5.10mm
Lens
Structure:
5
Elements / 3 Groups
Apparent
Field of View:
44
degrees (measured at
45Ė)
Height
& Width:
1.8
x 1.9" (measure
confirmed)
Weight:
4.2
oz
Barrel
Diameter:
1.25"
(measure confirmed)
Filter
Diameter:
28.6mm
(measure confirmed)
Field
Stop Diameter:
3.9mm
Eye
Relief:
3.6mm
(measured at 2.5mm)
Eye
Lens Diameter:
6.1mm
(measure confirmed)
The Pentax 2.5mm and
5mm XO series of eyepieces ("O" for visual Observation)
were released by Pentax for the 2003 Mars opposition event. Based on
my research of public online archives and marketing releases,
Pentax¡¦s optical design goals for the XO series were for the
achievement of an orthoscopic planetary eyepiece with maximum
transmission, maximum contrast, and maximum suppression of optical
aberration for telescopes with focal ratios as short as f/4.
Additional goals included ease of use and to be constructed of
eco-friendly materials containing no environmentally harmful
substances (such as arsenic which can be used to whiten or reduce the
green coloration of glass). As a result of these goals the XO series
incorporated high-refraction low-dispersion lanthanum glass elements,
the Pentax proprietary SMC full-surface multi-layer lens coatings
with the laminated optical elements additionally treated with partial
coatings for additional improvements, and the use of computer
simulations to determine the best placement for internal baffles and
blackening to maximize contrast and fully suppress any stray light.
As visualized in the illustration below, the 5mm XO is a 5 element /
3 group design (blue are lens elements), which incorporates five
different main baffles (red arrows show locations), and incorporates
thorough blackening and micro baffles throughout.
For the 5mm XO, Pentax
states it achieves a maximum transmission of 98%, which would mean
that a 99.6% to 99.7% efficiency would be required for each
air-to-glass interface to achieve the overall 98% transmission at the
green wavelengths, an amazing achievement for the circa 2003
technology. Based on available data, below are graphs illustrating
the 5mm XO¡¦s transmission curve as well as the distortion level
of the design. The blue line of the transmission graph shows the
percentage of transmission (y-axis) by wavelength of light (x-axis).
The green line of the distortion graph depicts rectilinear
distortion, commonly referred to as barrel and pincushion
distortions. For this graph the solid green line shows the
distortion level in percent (x-axis) as a function of the increasing
distance off-axis from the center of field (y-axis) -- quite
impressive being less than 5% when compared to other designs as can
be seen here -
http://www.users.bigpond.com/PJIFL/eyepieces_distortion.html).
As good as charts,
graphs, and design parameters may be, once an eyepiece enters the
complexity of an optical chain, the best laid plans of optical
designers can often go astray. So with all the lofty intentions of
the Pentax designers I wondered exactly how well this eyepiece would
fare once I put it to the ultimate challenge -- not in some sterile
bench test, but in the real-world, under real skies that take no
prisoners, and in real telescopes with all their flaws and challenges
trying to keep up with changing temperatures as an evening¡¦s
observation progresses.
For my first evening
out I took my Takahashi TSA-102 f/8 APO, pointed it at Jupiter, and
loaded my personal standard for performance the 5mm TMB
Supermonocentric. After observing for several minutes and noting
various surface details, levels of shadings, and colors (primarily of
the orbiting moons), I was ready for the 5mm XO. With my first view
through the XO all I could think was ¡§Wow! Impressive!
Definitely living up to its reputation.¡¨ And as this evening
progressed, and the many subsequent evenings using the 5mm XO in the
TSA, my smaller 80mm f/6 APM APO, and my Orion XT10 f/4.7 Dob, my
overall feeling was that compared to the other eyepieces in my
inventory, even the venerable TMB Supermonocentric, this diminutive
5mm XO could definitely hold a place as a planetary weapon of choice!
Focus snap, crispness of the details, depth of contrast, and
aberration control over its entire field of view were nothing less
than spectacular. My judgment of the XO¡¦s performance by
target or usage characteristic over the many evenings of use was as
follows.
Focus
Snap
Finding
best focus with the 5mm XO was never a chore, it decisively came to
sharpest focus almost immediately with little need to ¡§play¡¨
with the coarse or fine focusing controls. When I placed other
eyepieces or eyepiece and Barlow combinations of the same effective
focal length for comparison, even against the superbly executed TMB
Supermonocentrics, it was immediately apparent that the XO provided a
superior ability to snap to focus quickly and effectively.
Crispness
of Images
The term ¡§crispness¡¨ is something I have
come to use more and more, as opposed to the term sharpness or
resolution. The reason for this is that I feel it is a term where it
is evident that there are many variables which contribute to an image
being perceived as crisp (i.e., resolution, contrast, scatter,
minimized distortions, etc.), whereas many times terms like sharpness
or resolution can be interpreted more strictly and narrowly which is
not always the intent when trying to convey the impression of clarity
that an image an eyepiece provides. On its own, with no comparison,
the 5mm XO¡¦s image was always pleasingly crisp, giving the
impression that I was resolving all the details possible given what
the atmospheric seeing would allow.
When
comparing its crispness to other eyepieces, it was readily apparent
of the superior performance of the 5mm XO, even to my personal
standard of the TMB Supermonocentric. The personal surprise for me,
was both the degree of difference and even how atmospheric seeing
seemed not to level the differences as much as I am accustomed. When
judging most premium-level eyepieces, using the very stringent
demands of planetary observation where very minute differences can
make a difference in the view, it is usual that one eyepiece differs
from the other by what is generally termed as a ¡§hair¡¨ or
as ¡§splitting of a hair.¡¨ In the case of the 5mm XO I
felt the difference was immediate
and obvious.
At no time did I have to spend tens of minutes or more and many
switches back and forth to determine which eyepiece provide the
ultimate level of crispness and clarity of image. It was always
obvious when switching to the 5mm XO that the image improved, and
that the image degraded when moving to other eyepieces like my TV
Plossls, Meade 3000 smooth-sided Plossls, Radians, or the TMB
Supermoncentrics. And while it is not surprising for an eyepiece to
provide such an immediately noticeable difference, what was
personally surprising was that on evenings of less than excellent
seeing or transparency, when the atmosphere I have found usually
levels any differences between eyepieces, the XO still held its
ground and provided an overall more crisp and clear image.
Apparent
Contrast
Again,
instead of simply using the term ¡§contrast¡¨ I prefer to
instead use the term ¡§apparent contrast.¡¨ The reason for
this is that contrast, and the judging of contrast, can often be
quite a difficult thing to do effectively and divorce from other
non-contrast related variables, such as transmission and scatter. I
therefore use the term apparent contrast as a means of conveying that
any comparative judgment may include drivers from sources other than
simply levels of contrast, but that again things like transmission,
scatter, and other factors may also contribute to the overall
perception that darker areas seem to have a level of increased
darkness or lighter areas seem to be lighter. For the 5mm XO, this
was again an area when compared to other similar effective focal
length eyepieces that it was immediately apparent that it was doing a
better job. On Jupiter in particular, it was always obvious that the
atmospheric bands and structures appeared richer through the XO,
gradations of shading in the polar regions showed better as well, and
definition in and around the Great Red Spot was either newly visible
or more pronounced with the XO. When observing the Moon however,
apparent contrast improvement was not so obvious as will be further
detailed in the section on Lunar observing. Overall, on Jupiter, the
XO performed obviously better in terms of apparent contrast of the
image when compared to my other eyepieces.
Off-Axis
Performance
Overall
the off-axis performance of the 5mm XO was excellent, regardless of
the scope I used. In the fast f/4.7 Orion XT10 Dob the 5mm XO showed
a very slight amount of field curvature and lateral color in a region
far off-axis, perhaps five percent or so from the field stop where it
took approx 1/5 turn of fine focus know to correct the field
curvature. I also noticed some very minute astigmatism in this
region as well but it was only detectable if I racked the image out
of focus, in focus the star image appeared non-astigmatic. No
rectilinear distortions were evident as I panned star fields. Moving
to a slightly slower 80mm f/6.25 APO, astigmatism was no longer
present and only the slightest amount of field curvature was seen
right at the field stop, taking only a slight touch of the fine focus
to correct. In the 102mm f/8 APO stars were sharp to the edge -- as
example, Polaris remained a nice airy disk with the companion fully
visible with no change in appearance right the to field stop.
Eye
Relief
I
would characterize the eye relief as tight and at times felt it was
difficult to get close enough to see the entire field of view. Also
of note is that the measured eye relief was shorter than the
manufacturer¡¦s claim (I re-measured several times to verify and
each time came up with the same result). Even though the eye relief
was definitely tight, as I used the eyepiece more and more, I became
more adept as getting close enough to take in the entire field of
view. I also found it quite acceptable to back off from the eyepiece
and not take in the entire Field of View for more comfort, as it was
easy to then simply use oblique viewing to observe objects as they
drifted to the very edge of the field stop.
Planets
(Jupiter)
Jupiter
provided wonderfully crisp and detailed views using the 5mm XO in all
my scopes. Fine planetary details were more easily visible and all
details were rendered as more obvious and with more apparent contrast
when compared to my other eyepieces. I judged scatter as being
either similar or very slightly more than in the TMB Supermonocentric
which I judge as excellent. Jupiter¡¦s brightness using the XO
seemed slightly better than other eyepieces and the tone I would say
is fairly neutral, although just a little warmer than the TMB
Supermonocentric which is one of the most color-neutral eyepieces I
have used. The XO rendered the colors of Jupiter¡¦s moons not
quite as richly as the TMB Supermonocentric did, and in particular
Ganymede could be seen as a degree more orange in color with the TMB
Supermonocentric. Overall the XO¡¦s performance on Jupiter was
quite impressive, and I preferred its rendering of the jovian planet
over that of the TMB Supermonocentric because more details visible
within the NEB and SEB, shadings were more prominent within the GRS,
fine structures around the GRS were better defined, and polar
shadings were both richer and more extensively defined in the XO than
all other eyepieces in my collection.
Lunar
(The Moon)
Lunar
performance seemed to be more level across the various eyepieces I
used; all showing extremely crisp and detailed views of the lunar
surface. Focus snap with the XO was easily best, and again the tone
it produced seemed slightly warmer when compared to the TMB
Supermonocentric. Areas of the lunar surface which were away from
the terminator and illuminated more or less flatly and face-on were
noted to have better apparent contrast using the XO, being for
example more richly rendered in the area around the Apollo 17 landing
site which I generally use as one of my standards for assessing
contrast levels. Obliquely illuminated areas near the lunar
terminator showed details slightly crisper that through my other
eyepieces, including the TMB Supermonocentric, examples include the
outcroppings in Crater Shiller and details around Promontorium
Kelvin. While this improved performance could be detected with
careful examination, it was not so obvious as the improved
performance the XO showed for Jupiter relative to other eyepieces,
instead being what I would call a hair-split better.
Where
the XO did perform obviously better than all my other eyepieces, was
in the rendering of white ejecta material in and around craters. As
example, the white wisps of ejecta within the craters around
Aristarcus in Schroters Valley on Luna were both crisper and more
detailed using the XO. With my other eyepieces, including the TMB
Supermonocentric, the white rays of ejecta within the prominent
craters in the valley (white arrow in picture) were observed as a
more non-descript lighter and milky-white brighter area. Through the
XO however, a fine latticework of detail was clearly evident within
the rays of ejecta extending into the crater, showing significant
fine structure and many variations of shading.
Stars
(Albiero)
Overall
the XO rendered star colors as richly as other eyepieces, including
the TMB Supermonocentric. However, transmission did seem very
slightly less when compared to the TMB Supermonocentric when viewing
Albiero. Scatter also seemed very slightly more with the XO than
with the TMB Supermonocentric, but this was again a real hair split.
Overall I did not prefer view of this colorful double any better
through either the Pentax XO or the TMB Supermonocentric.
Nebula
(M57)
My
initial views of the Ring Nebula were on evenings when the
atmospheric transparency was less than optimal and my moderately
light polluted observing location was not at its best. Under these
conditions, where the background sky was brighter than I liked, the
Ring Nebula was rendered with a starker contrast between the Ring and
the background sky with the TMB Supermonocentric than with the XO.
However, as the weeks progressed and I had many more evenings of
darker and more transparent skies, I was no longer able to detect any
difference in how the XO performed on the Ring versus the TMB
Supermonocentric. Therefore, under darker skies both eyepieces
provided excellent rendering of the Ring Nebula and the faint
companion star just outside the Ring.
Globular
Clusters (M13)
In
all three of my telescopes, from the 10¡¨ Dob to he 80mm APO,
the 5mm XO provided a better view of the M13 Globular Cluster,
increasingly so as the aperture of the instrument was reduced.
Basically the level of distinct and separate stars that could be
easily seen across the entire cluster was more pronounced using the
XO. This advantage was most notable in the smaller 80mm instrument
where other eyepieces showed a more or less non-descript cotton ball
view of the globular cluster, using the XO individual stars were
clearly and prominently evident.
Open
Clusters (NGC 869)
My
final observations with the 5mm XO were of the Perseus Double
Cluster. Similar to the views of M13, the 5mm XO rendered these open
clusters a degree better than my other eyepieces. With the XO
brighter stars across the clusters popped with more prominence giving
the clusters a more three-dimensional character than the other
eyepieces could produce. Again, this ability of the XO over the
other eyepieces was more pronounced as the aperture of the telescope
was reduced, making the XO a valuable asset for my smaller 80mm
telescopes where every ounce of performance capability from an
eyepiece can be extremely valuable.
Conclusions
Overall I felt the
Pentax 5mm XO was an outstanding world-class performer -- and
interestingly the only eyepiece I have come across where I can say
that its non- planetary purist more than four element design had
absolutely no visible degradation to the planetary view to my eye.
While not a large Apparent Field of View at 44 degrees, it did not
feel restrictive like a typical 40-42 degree ABBE Orthoscopic or 30
degree Monocentric. As a result, I found it very pleasurable to use
as a non-eyeglass wearer and I found myself reaching for it more and
more to the exclusion of my other eyepieces of similar focal length.
As reported, contrast, transmission, scatter, and sharpness were
impressive to say the least. As a planetary eyepiece I felt the
Pentax 5mm XO is squarely in the class of the venerable Zeiss ABBE
Orthoscopics and could easily stand as the prized part of an eyepiece
arsenal for the lunar and planetary enthusiast. Very much
recommended. |
