Home / What’s Up Cygnus (2)
by Steve Coe 10/13/09 | Email Author
 Voice your opinion about this topic in the forums
From my viewpoint in Arizona Cygnus is “the constellation that never goes away”. It seems to be up late in autumn, we have even seen it on the western horizon in January, and then is rises again in April and stays nearly overhead for half a year. A constellation with this much to view and all that time to view it yields many observations. Let’s take a look.
NGC 7000 is the North America Nebula. This large area of nebulosity needs a rich field telescope (RFT) to be seen in its entirety. A dim glow can be seen in the area with the naked eye and 10 X 50 binoculars at a dark site will show the North America shape. In a 4 1/4" f/4 with a 20mm Erfle and a UHC filter, the nebula is very bright and very large, filling the field with nebulosity. The brightest section is "Mexico" and the Pelican Nebula (IC 5067) can be seen nearby.
I enjoyed the small RFT so much I decided to build a 6" f/6 Newtonian RFT. On a night I rated 7/10 for transparency the view of the North American was one of the best I have ever seen. Using a friend’s 35mm Panoptic and 2" UHC filter, there is nebulosity all over the field, with "Mexico" the brightest section. There are several dark lanes within the “continental” shape, and many stars involved in the nebula. The star cluster NGC 6997 is pretty bright, pretty large and somewhat compressed with 11 stars resolved in the 6 incher. Going to a 22mm Panoptic shows the cluster having 18 stars resolved, 8 are very faint and there is an obvious glow on un-resolved stars around the cluster. The "Pelican" section is obvious. This also cost me some money, I purchased a 35mm Panoptic after this viewing session and have never regretted it.
Every once in a while I have an astrophoto of my own that I feel the urge to insert in one of these articles. Here is a shot on film with my 135mm f/3.5 lens. It is a 30 minutes exposure on Fuji 800 film. Notice the rich star field above the North America Nebula.
NGC 7008 is a pretty bright, pretty large and round planetary nebula at 200X using a 17.5" telescope. It has several irregular bright spots and three stars are involved in the nebula. There is a nice blue and gold double star at its edge. Using the 13" some years later, I said the nebula is elongated 2 X 1 in PA 45, also that there is a nice dark lane in the nebulosity.
Viewing through a 6" f/8 refractor with a 14mm eyepiece this nebula is pretty bright, pretty small, elongated 2X1 in PA 45 degrees and 1 star is involved approximately in the center. There is a double star attached at its edge. Going to the 6.7mm eyepiece shows the central star easier and the double star appears as light yellow and light blue with fair color contrast.
NGC 7026 is a planetary nebula with a very unusual shape. Observing with Larry Mitchell’s 36" shows this nebula as truly bizarre. It appears like two pancakes edge-on with blackberry syrup in between them. It appears as two pretty bright, small, short arcs of nebulosity with a thin area of darkness between them. The nebulosity grows to double its' size with averted vision. No central star is seen.
Dropping back in aperture to a Nexstar 11 inch SCT on a good night about 100 miles from Phoenix it is easily seen at 120X. My notes say it is pretty bright, pretty small and elongated 1.8X1. Going to 320X provides a nice view, there are now two pieces to this nebula and averted vision makes it much larger.
NGC 7027 is an emission nebula that gets included with planetaries because it is only 5" in size, a reasonable error. It seems bright, pretty small and elongated 2X1 in PA 135 at 135X in the 17.5 inch. The central star is seen occasionally and it has a nice blue-green color. This nebula is somewhat rectangular and has a bright spot on the NW side at 220X. Moving up to 330X will hold the star more steady, but something truly strange has happened, the star is seen as light aqua in color. I assume that this fascinating effect happens because the star is embedded deep within the nebula from our point of view. Don’t miss it if you have a chance to observe this strange nebula.
M 39 is a very bright, large and loose cluster northeast of the star Deneb. In dark skies, this cluster is naked eye and was noted by Aristotle in 325 B.C. as a comet like object. Only at the darkest observing locations I have seen it naked eye and I found it best with averted vision. Using 10X50 binoculars I counted 17 stars involved within a triangular cluster that stands out well from the Milky Way background glow. In a 6" f/6 Maksutov-Newtonian and a 22mm Panoptic it is bright, very large and is somewhat scattered. I resolved 38 stars within the cluster. There are several nice pairs of stars involved. You feel like even with only 6 inches of aperture, you got all that this big splashy cluster has to offer.
Le Gentil 3 is also the Northern Coal Sack, this huge dark marking in the Milky Way is between Cygnus and Cepheus, with the cluster M 39 near its edge. It is impressive even with the naked eye and cuts the Milky Way right through. Even my wide field binoculars, 8X42 with a six degree field, don't quite take it all in. The central oval section fits with a lovely chain of stars outlining the dark contour on the north and west sides. I would estimate that the central oval is 4 X 6 degrees and has 22 stars enveloped within the dark cloud. The "extension" from this dark oval is toward the east it is about two degrees long and one degree wide with M 39 on its edge. Moving up to the 4 inch f/6 RFT with a 22mm Panoptic eyepiece shows some beautiful dark lanes that create a lace effect from the interplay of light and dark. All in all, a fascinating area; centered at 21h 13m and +50 42.
Here is my image of LeG 3 with a 35mm lens. The bright star on the right is Deneb and the North American Nebula is below it. The dark area in the center of the image is LeG 3. M 39 is below it, at this scale it is pretty small and only resolves about 8 stars.
Back to Top
Contact Us
CN Reports | Reviews | Articles | Forums | Classifieds | About Us
Copyright© 2004 Ad Libs Advertising.
Privacy Policy
  Search Cloudy Nights
  Advanced Search
Sunday, November 22, 2009
Cloudy Nights Supporters
Astronomics
 www.astronomics.com
International Year of Astronomy 2009
Cloudy Nights is
the Official Forums
for IYA 2009
