Binocular Universe:
Bikini
Bottom
October
2009
April
showers may bring May flowers here on Earth, but up in the sky, October is the
soggiest time of year. That's
because the "wet quarter" flows above our southern horizons this
month, bringing with it several constellations that are associated with water in
one way or the other. There are
Capricornus, the Sea-Goat; Aquarius, the Water-Bearer; Piscis Austrinus, the
Southern Fish; Cetus, the Whale; and Pisces, the Fishes.
None are striking from a naked-eye perspective, so you may need to travel
to a site that is free of terrestrial obstructions, low-slung light pollution,
and any horizon-hugging haze to make them out.
Except
this year. That's because these
evenings Capricornus, which always impresses me more as the bottom half of a
bikini than a "sea-goat (whatever that is) plays host to brilliant Jupiter. The king of the
planets draws the attention of
everyone from all quarters to the wet quarter, whether you're in the heart of a
city or somewhere out in the rural countryside.
Binoculars
easily show the four Galilean moons
orbiting Jupiter. These serve as a
fitting tribute to the man who, 400 years ago, solved the thousand-year-old
riddle of which orbits which, Earth around the Sun or the Sun around Earth.
The fact that Galileo saw what he called four "stars" --
originally, the "Medici stars" -- orbiting Jupiter proved that not
everything went around Earth, as Ptolemy's geocentric gospel had prescribed
since about 140 AD.
It's
fun to watch the acrobatics of the Galilean satellites as they shift from one
side of the planet to the other. Can
you identify all four through your binoculars?
To find out which is which, use Sky
& Telescope's Jupiter's
Moons Javascript Utility. For
instance, on October 17 at
00:00
UT (which is the evening of October 16 in
North America
), all four moons will appear extended in a straight line to the west of the
planet. Twenty-four hours later, Io
and Europa will have shifted to the east of the planet.
As
an aside, as you are showing Jupiter and its moons to family and friends, please
don't commit the same error found in many undergraduate astronomy textbooks by
referring to Jupiter as a "gas giant."
It's not. For most of its
thickness, Jupiter consists of a strange cocktail called metallic hydrogen.
Metallic hydrogen, which is electrically conductive, is not gaseous.
At the pressures and conditions found within Jupiter's interior, metallic
hydrogen is a liquid. So, call it a
"giant planet" or a "Jovian planet," but a "gas
giant?" No.
Finder chart for Capricornus. Chart
from TUBA, www.philharrington.net/tuba.htm
Another
giant of the solar system, the eighth planet,
Neptune
, looms not far to the east of Jupiter this fall.
Since it was discovered in September 1846,
Neptune
has marched slowly around the sky, but has yet to complete a full orbit.
Look for it to the east-northeast of a line of three equally spaced stars
north of Deneb Algedi (ä Capricorni).
Neptune
only shines at 8th magnitude -- six times fainter than the Galilean moons -- so
it may take some searching before it is found.
Use the map here to spot it. My
10x50s hint at the planet’s unusual turquoise color, which may also help you
to pick it out from the surroundings.
To
the west of Jupiter, we find two double stars that are ideal for binoculars.
First, at the northwestern corner of the constellation’s triangular
outline, we find Algedi, or Alpha (á)
Capricorni. Algedi is made up of two
4th-magnitude stars that are easy to see even through a pair of small pocket
binoculars. They may look the same,
but it turns out that the two stars are nowhere near each other in space. The
yellow giant eastern star, known as Alpha-2, is 109 light years from us, while
Alpha-1, a yellow supergiant, is nearly seven times further away.
Algedi (top), Dabih
(bottom), and surroundings, as seen through the author's 10x50
binoculars. North is up and east is to the left in the drawing.
The
second double star is Dabih, or Beta
(â) Capricorni, is just south of Algedi in the same field of view. While
Algedi's two stars appear identically bright, Dabih's two stars look markedly
different. The brighter sun, called
Dabih-Major, shines at 3rd magnitude, while its companion, Dabih-Minor, is 16
times fainter at 6th magnitude. They
may look different, but studies show that both form a physical system 330 light
years away. Each is separated from
the other by about a third of a light year. As
a result, it takes at least one million years for the pair to orbit one another.
There
is much more here than meets the eye. Studies
show that Dabih-Minor is a spectroscopic binary dominated by a blue-white giant
that is unusually rich in platinum, gold, mercury, and bismuth.
Dabih-Major is an orange giant that is circled by a close-set pair of
stars. The more massive of those two
is a blue star, but little is known about its companion apart from it taking
only 8.7 days to orbit. The two are
separated from each other by only one-third Mercury's distance from the Sun.
Our
last stop within Capricornus is the constellation’s sole contribution to the
Messier catalog. The 7th-magnitude
globular cluster M30 lies in the
constellation’s barren southeastern corner.
The stars Nashira and Deneb Algedi mark the Sea-Goat's tail and the
eastern point of the Capricornus triangle. Turn
southwest toward the triangle's southern tip, pausing partway along the way at
the 4th-magnitude star Zeta Capricorni. Center
Zeta in your finderscope, then look toward the eastern edge of the field.
A 5th-magnitude star, 41 Capricorni, should just be coming into view.
Center on 41, and then look just to that star's west.
Can you see a dim, round patch of grayish light surrounding a brighter
core? That’s M30.
It will take at least a 6-inch (150-mm) telescope to show any sign of the
100,000 or so individual stars that make up this distant swarm.
While
you're in the area, be sure to try to spot the globular cluster M72,
the tiny 4-star asterism M73, and
planetary nebula NGC 7009.
All lie across the border in Aquarius, and are shown on the chart above
and listed below.
That's
the view from Bikini Bottom. Comments,
questions, suggestions for this column? Post
them in the discussion thread or drop me a line.
Till next month, when we will once again tour the universe through our
binoculars, remember that two eyes are better than one.
About
the Author:
Phil
Harrington, author of Touring the Universe through Binoculars, is
currently completing a new observing guide of challenging observing
targets for Cambridge University Press, which will be published in late
2010. Visit his web site at www.philharrington.net.
Phil Harrington's Binocular Universe is copyright 2009 by
Philip S. Harrington. All rights
reserved. No reproduction, in whole
or in part, beyond single copies for use by an individual, is permitted without
written permission of the copyright holder.
